H
hands2bfree
Long story ill try to supply all the info:
moved into house - evident the heating had never been touched since 5 years ago when a new baxi back oiler was installed, mix ages of rads throughout the house.
the system is gravity fed
pump working but not sure how to bleed- do i just remove the disc cover?
first, down stairs rad in living room never got hot
second, box room was cold - rad bleed valve was rounded over - so could not bleed system
third, conservatory rad cold.
fourth, dining room and 2 bedrooms rad hot
I replaced the box room rad, but system still same after bleeding
I emptied the system through and filled up + inhibitor.
Still same issue with rads, but with knocking = plumber recommended a solution that that disperses air locks.
poured the solution in and then all rads went cold.
tried heating non stop on high for a few days but no results.
i emptied the system and put clean water in, but still no warm rads.
but i hear knocking again.
any ideas would be welome
