I have a puzzling problem. We moved to a house middle of last year with a air source heatpump and radiators with TRVs, house is 3 years old. The heating has not really been called upon much until the winter. We have 2 zones, upstairs and downstairs.
Everything fine upstairs, all radiators working fine. Downstairs was problematic, which I finally identified was a faulty zone valve head, which I replaced and all appeared to be working. However I have 2 radiators downstairs which never get hot, they don't even get tepid. Completely stone cold.
I have bled all the radiators, the pressure at the storage unit is 1 bar. I tried removing the TRV and checking the pin was not stuck underneath. I checked the LS valve was open. I have also completely removed one of the radiators and flushed through the radiator in the garden. While I had the radiator off I opened the LS valve and water under some pressure was coming out, repeated on the other side by opening the TRV valve and had a similar result. I've tried closing the other radiators, still no heat and finally tried balancing the other radiators using guidance online, with a lower temperature gradient on either side (5C) of the working radiators to account for lower teperature feed from the heat pump system.
Admittedly I didn't release lots of water from either the TRV or LS side when I had the radiator off but it seemed to flow quite well.
I am now at a loss, Any ideas?
