My CH system works fine (i.e. all rads up and downstairs are hot) most of the time.
However, when i run a bath, the rads go cold downstairs.
The rads downstairs only heat back up again until when the HW cylinder is back at the correct temperature.
I understand that when the temperature drops in the HW cylinder that the 3 way MV value will open (HW side). It's strange. It's almost like theres not enough pressure (i.e. to much resistance) to heat the rads upstairs, downstairs and the HW at the same time.
Note that the MV and pump were new last year.
The pump is on max speed.
I have had fernox system restorer/cleaner around the system twice.
I have flushed out every RAD downstairs and flushed the flow and return pipes out the ran clear.
Turned all the locksheilds on the upstairs rads to half turn then quarter turn.
Any ideas???
Any ideas?
Any ideas???
Any ideas?
