I have done a lot of searching on this topic and its clear that (at least to me) its unclear as to what the best plan is with a cold roof.
I have an existing 4 x 4.5m flat roof build in the mid 1970's and is enclosed on three sides by other parts of the house - so only one side could be vented through the eaves and to add further complexity it has a 6 tile pitched parapet too. the original roof was unvented with 10cm of rockwool packed imbetween the joists up to the deck above - no vapour barrier - no venting.
The roof sits on 9x2" rafters and sits on firings strips to allow water runoff to the "open" side.
So far we have had new OSB put on top of the existing decking boards and EDPM installed. All good so far.
My original plan was going to be:
EPDM
OSB
5 cm void
20 cm rockwool
Vapour barrier
Plasterboard with VB
ensure eaves on "open" side had appropriate venting holes
However - reading some of the posts on here it would seem that packing the entire joist depth with rockwool ensuring there are no air voids and using a vapour barrier would essentially prevent any potential build-up of condensation and negate the need for any venting.
I know +woody+ has kindly explained on numerous posts previously that this "composite roof" containing a full insulation layer from upper deck board to vapour barrier removes the potential for condensation to even occur - but all the other literature I look at (e.g., Bauder and others) all advocate venting above the insulation/eaves etc
Thanks for your counsel in advance
Tim
EPDM
OSB
5 cm void
20 cm rockwool
Vapour barrier
Tim
