Hi all,
I have a 22' x 14' flat roofed extension that i am currently renovating.
When i initially removed all the ceiling plasterboard, the roof void was filled with old insulation and appeared to have minimal ventilation., although no damp / condensation was evident.
As i build back up, i was intending to fit 100mm celotex insulation between the 8" joists - therefore leaving an additonal 100mm airspace above the insulation and creating a 'cold' roof??
If i add some additonal ventilation to the soffits / fascias is this construction going to be ok?
Thanks....
Thanks....
