Ok this is a question about my shower at home.
Our boiler isn't the best and we haven't been happy with it for a while but we have the service plan from ****ish Gas and we ask them about the fact the boiler takes so long to heat up hot water and if you turn it to full flow, it seems to go cold again.
Anyway we've dealt with it for four years now, but all of a sudden we've recently found that the shower has gone cold. I know the weather is obviously cold, but we've never had this problem before at winter and it was still reasonably warm outside when this first happened.
Under normal operation, if we turn on a hot tap, after a not so short while, the water does get hot. At the moment the water is hot enough that if you run it slowly enough it is too hot to handle, but if we increase the flow a little with the tap it levels out at a more manageable temperature, but if we completely open the tap, it's just warm.
I like a cold shower, but it doesn't seem to matter what we set the Bristan Artisan (4 years old) at, we cannot get it to warm up unless we run the cold tap in the sink while the shower is running, then it gets a little bit warmer.
I bought a new shower valve off the net and just fitted it when I got home from work this evening. It is a vast improvement, but I still wouldn't say the water gets hot, even if I turn the valve right up in temp.
Anyone got any ideas?
