I have a single window gabled dormer which has just had its window replaced with a new double glazing unit. Despite replacing the DGing the area still feels cold. After taking to neighbours it would appear that the insulation around the dormer is not great.
I can get in to insulate some of the dormer through an internal access panel, however under the window and to the right of the window there is no access. I assume I could remove the plasterboard and insulate behind it, however, I'd like to keep disruption to a minimum (it's a kids room). Someone suggested that I could drill some holes through the plasterboard and put some expanding foam (fire retardant) through the holes to insulate it. Is this a reasonable thing to do?
