apologies if this has been asked before but I haven't been able to find an answer using the search ..
My house has all the cold taps supplied direct from the mains. No problem until you put mixer taps on, which I've now done, and then you can't really get a sensible controlled temperature out of them, as the cold pressure is ~5bar and the maximum hot pressure is about 1 bar downstairs.
My question is - is it legal and possible to fit a new cold supply to the main storage tank in the loft and then shift what was the mains water feed to the tank/taps to be fed from the cold header tank and so provide balanced cold (and hot) to all the taps in the house? Hope that makes sense!
Cheers for any advice.
