Any help with a tap problem would be great. The cold tap on our bathroom sink has stopped working. You can turn it until it stops but no water comes out. This happened a week ago, then it returned to a fairly weak trickle and now it has stopped again, completely. Oddly, the hot tap has also slowed quite a lot recently. Both taps on the bath in the same room seem to be fine. Any ideas on what might be causing this. Air bubble? And also on how to fix. Both taps have isolation valves on the pipes as they go towards the bottom of the sink. Many thanks in advance,
Cheddarman
Cheddarman
