Cold wall in bedroom
14 Nov 2010
Hello,
We shifted our sons bedroom around the other day and were shocked to find black mould / stains on one wall behind the bed. It's an (almost) external wall that is cold.
The bedroom is above the garage and 1/3 of the bedroom ceiling slopes down as it's the underside of the garage roof. The ceiling slopes down to a wall that's approx 3' high x 3m long. This is the cold wall. I assuming that behind this wall is the remainder of the roof space that's just been boarded up hence the coldness on the other side.
There's no access into this space so was going to fix vertical battens, 50mm Celotex then foil backed plasterboard. Are there any easier things we could try first? Is this correct? Could i cut in 2 louvre vents (1 either side of the bed)?
I want to chop a hole in the wall and do the same from the other side instead but my partner is against it as the spiders may come in
The room is well ventilated and heated.
Black mould can cause health problems good you uncovered it
It might be ventilated but clearly there is no circulation behind the bed against the cold wall.
You say the room is being re-arranged, is the bed still staying where it is? Because if not and the wall is uncovered, and you say there is ventilation in the room, the problem is likely to go away.
Humidity is causing the problem in the room, feeding the mould, perhaps running a de-humidifier periodically will help?
Thanks. It wasn't good to look at, pretty worrying really but the wall is nice and clean now. We'll try the dehump option too. We've rearranged the room slightly so there's now 1' between the bed and wall :)
