We bought a house recently and I've just found that the cold water 28mm gate valve is stuck open. It is as far as I can see the only way of cutting off the cold water supply from the tank situated in the loft.
I suspect it hadn't been open for approximately 10 years. Any recommendations on how to get it unstuck? Is it limescale that gets these things stuck? Is there a product I can add to the cold water tank to remove limescale? Blowing a hairdryer on the valve to release it? Tried WD40 already and a bit of knocking with a hammer.
I'd rather not have to replace it but if I do, I guess I'll drain the cold water tank first, remove the old valve using a pipe wrench and replace with a new one with a compression fitting?
Thanks.
Thanks.
