cold water cistern
30 Oct 2005
Cheshire
what size of cistern tank would you recommend when fitting a 2.2 bar pump for a mixer shower as the one in at the mo is 25 gallon so was thinking around 42 as it will also have to feed a bath/shower mixer tap which has to have an independent feed for the cold rather than direct mains... thanks
Depending on the shower outlet you might shift 4 galls/minute, so 40 is too small I'd say. 2 x 50?
