I've found the culprit to the pressure dropping in my unvented system. Its a dripping cold water combination valve. I unscrewed the pipe exiting it and found the leak, so its definitely that. I also recharged the expansion vessel anyway.
I've had the plumber out and now know how damn expensive these things are. He's said £190 to replace which seems fair as the part is so expensive. I was wondering if he needs to replace the pressure reducing cartridge and line strainer as well as the expansion relief valve?
Its an Ariston Classico 125 cylinder if that makes a difference.
