Hopefully someone can shed some light on my problem.
I've got a Keston C36 combi boiler in my 2 bedroom flat. The boiler is sensing that the DHW flow rate is ~2.5 liters/min which is on the borderline hence the doesn't fire up at times. This is happening at all the hot water taps in the flat (i've clean the aerator on all of them). The static water pressure is coming in at 3 bars while the cold water flow rate is ~9 liters/min. So my questions
1. Is it normal to have such a big difference between cold and hot water flow rates?
2. Any ideas what could be wrong?
