Hello, can anybody help with advice please?
We recently had the Water Board out to test our cold water flow as a boiler seller blokies advised that it wasn't sufficient for a combi boiler, which I want to put in to lose the hot water tank to make space for a shower cubicle.
The test showed that it was fine outside at the main (44 or more) but wasn't enough after that, so then the conversation turned of course to upgrading the pipes etc, specifically from the mains stopcock in the street to the stopcock in our property, because in our 100+ year old property the mains pipes will be the original cast iron ones and therefore corroded inside and therefore narrower bore and that will be the reason for the 6 or less flow indoors (flow of 10+ required for combi boiler).
The Water Board man very magnanimously said "Don't get us to do it because we're expensive", so I'm thinking now that he is inferring that a plumber can do it and the Water Board only have to come along and find a loose connection for them to connect to the street main (and when they came they automatically replaced the stopcock in the street for a new one as a matter of standard policy)?
My question is when the new pipe comes into the house and connects to the existing stopcock, what about how does the cold water supply get round the house, to the outlets and the boiler and washer and cold water tank etc? Would there not be the same 100 year old pipes internally or is there something in relation to that, that as a plumbing ignoramus I am missing? Is upgrading from street main to indoor stopcock all that is required or is there potentially more to consider?
Any advice appreciated.
Thanks - Simon.
Thanks - Simon.
