Hi
I have a Atag ic Economiser Plus 27, which now and again stops supplying hot water. Everything works fine then after a week or two weeks cold water from the hot taps. If you leave it for a while, half an hour, or first time it happened a day, the hot water is back. Since the boiler is only a few month old called Atag they diagnosed it as a faulty flow sensor they contacted the installer a new sensor was installed, engineer said he could not see a problem with the sensor (no missing vanes)but would change it anyway. This appeared to fix the problem, unfortunately not. Engineer retuned diagnosed it as mixer tap or shower bar passing. As when he isolated the DHW at the boiler (don't quite know how he did this, as the service manual shows the DHW is the second output from the left, which on my boiler does not have an isolation valve. The isolation valve on my boiler is for central heating, maybe this is common to both DHW and central heating) the hot tap continued to flow for a short while. After feeling the pipework on the shower he suspected that it was the shower mixer that was passing cold to hot. Had a new shower fitted, after a couple of days the problem is back again.
Any suggestion very much appreciated
