Hi all, I am wanting to raise my cold water tank to gain more pressure/flow etc etc, in my loft there is the chimney breast which at the bottom has a nice concrete lintel which protrubes the brick wore by 3"
If the first pic you can see the area i plan to build a structure to house the tank.
I've tried to put measurements on the pic to help with my question.
Will the two wooden beams that are going from the brick wall into the other end of the roof space strong-enough to take the weight of a tank.
The other end is a sloped roof (i'm end terraced) so the top beam is only supported by the beams that run from top of roof to the bottom.
I do have a pic of this but not on the works computer.
Sorry for the sketchy information, i will post better pictures when i get home but just thought i'd start the ball rolling, many thanks
