Cold water supply to kitchen tap, dishwasher and washing machine
30 Mar 2015
Hi All,
I currently have a cold water supply pipe (15mm plastic) coming out of the kitchen unit. This needs to service the kitchen tap, dishwasher and washing machine. I am wondering if there is a suitable fitting to feed all of these or how I should arrange the pipework to ensure maximum flow, etc.
Thanks in advance
Par for the course I'd say.....washing machine / dishwasher demands aren't great or continuous so any reduction to the kitchen tap would be minimal.
John :)
What's normal in these circumstances? I should have stated that this is a DIY project but I have done some plumbing in the past.
My own supply is blue MDPE which reduces to 15mm within the building......static pressure 3 bar.
No problems with any appliance or supply but of course you can tell if more than one tap is open.
John :)
thanks @newboy. That's very helpful. Since, I have hep20 coming out of the ground, I'm inclined to continue with this in which case I will get the HEP equivalent fittings of what you have suggested.
Been doing some more digging on this and it transpires that there is no Washing machine tee valve in the Hep20 system. The closest appears to be this:
http://www.screwfix.com/p/hep2o-hx18-15ws-straight-service-valve-15mm/9258f
This will require a Tee off my single pipe coming out of the ground and then a short stub of pipe connected into one of these. the same would then be repeated for the dishwasher and finally, I would have one of these for the tap pipes to connect into:
http://www.screwfix.com/p/hep2o-hx2...tracking url&gclid=CJW8vriagdECFSIG0wodQu8G6A
Is this sensible?
The Hep service valve won't connect to the w/m or d/w
What are you planning to connect to the brass/Hep adaptor?
ohh, what do I use in the hep range for the dishwasher and washing machine?
the geo brass fitting would be for the flexible tap pipe to connect onto
thanks again. You posted the same link twice - in case you we're intending something else.
presumably I still need the tee and short stub of pipe to precede these appliance valves?
I've also noted your point on the isolator for the taps. A thought - could this same fitting not be used for the tap too?
Apologies, it should have been a link to these - http://www.screwfix.com/p/hep2o-hd10-15w-equal-tees-15-x-15-x-15mm-10-pack/4500f
yes (and don't forget the inserts :))
No - the tap tails won't connect to the appliance valve
Guys, given that I will be using the Hep20 fittings and I already have the Hep20 pipes coming out of the ground (I need to connect to these), I assume that Hep20 pipe is the way to go with the rest of this as opposed to copper pipe in conjunction with Hep20 fittings?
It all depends really. Nowt wrong with Hep but I do like the look of copper and it's resistance to getting banged/jammed/pulled or chewed.
