Hi all,
Wonder whether anyone can help with the following question. I need to connect up a downstairs bathroom to the cold water cistern in the loft so that I can use balanced pressure mixer valves (at present bathroom cold water is high pressure mains fed whilst hot water is low pressure gravity fed).
Can I do this by drawing water from a new branch running off the top of the 22mm pipe that feeds cold water from the cistern to the hot water tank? Or do I need to insert a separate outlet from the cistern?
In the case of the former option the branch would lie about a foot below the cistern, but high enough above the inlet into the hot water tank, I think, to prevent heat from the hot water tank affecting the new cold water supply.
Any suggestions or advice would be much appreciated.
Mike
Mike
