Hi All
My cold water tank is constantly filling. The float valve and ballcock were really old, so I went to a local plumbers merchant today and was advised to replace it.
I did this earlier today, (part 1) for a (part 1) and have bent the arm to the required water level.
It doesn't cut of automatically after running off water.
I can stop the filling manually (by pushing down the ballcock to re-fill faster) but after a few minutes it starts to drip and then flow.
I have had problems in the past and had to support the side of the tank to position the pipe, I have tried doing this again from underneath the pipe and between the wall and the tank, it works for a few minutes but then continues to fill.
Has anyone got any ideas?
Thank you
Suzi
Thank you
Suzi
