We have two water tanks in our loft, one is lagged and has a lid and the outgoing pipes are lagged, so I presume this is something to do with hot water taps or central heating.
The other is a much older white plastic tank, containing cold water. It doesn't have a proper lid, just an old sheet of plywood resting on top which doesn't fit properly, there is a gap on one edge. There is some 'debris in the bottom of the tank, as well as cobwebs inside above the waterline, and even a dead 'fossilised' fly on the inside of the plywood sheet. The plywood has turned black at one end, has peeled away and is dipping into the water.
When I turn on the cold taps in my bathroom, the ballcock activates and the tank starts to refill (much to my horror)
Does this mean that the water inside that tank contains the cold water that I brush my teeth and gargle with every day? and if so, how long have I got to live
Is this a potential major health hazard and should I replace the tank or just get a new lid?
