As you seem to only be able to buy cold water filling washing machines these days and most people usually have a tank full of hot water, is it OK to connect the machine to the hot water supply?
The problem is on the cooler washes 30 and 40 degrees for more delicates your water is going to be way too hot and you will get a less efficient rinse with hot water
