colour change bright to very bright 50-50 led strip
12 Jul 2004
Surrey
years ago it was easy search on e bay for 50.50 led 5m with 6amp supply
i now want colour change internal 5m bright at minimum with the option to go brighter iff possible now usb are no good to man nor beast for good illumination as about 10% the wattage needed but all i seem to be offered
now i may be thick on this but is the option for colour change bright 5m can anyone give me a link please on ebay as my searches have provided no joy
Since most (all?) of these devices come from China, you may as well go to the "source".
I suggest that you check on
to see what is "available" and the (low) prices.
Many of these run on a 12 V plug-in "Power Supply" - you just need to select one suitable for UK Voltage and Plug connection.
This one may be suitable for you:-
(Go to the UK Plug options.)
(Note: If Postage is not specified, it is usually (individually) the equivalent of [about] €2 - and, takes about 10 days
Order multiple other items [with the same "Order"] and the Postage is usually the same.)
thank you both for your answer
its the fully flexible tape stick on type i am after as its a 1.7x2.3m lean too so at least 2 random change off directions
what i was after was perhaps 80-100w lightbulb equivalent [about 1000 -1250 lumins ] so 200-250 lumins a metre
i am happy with say a60w /800lumin top end but colour change dimmable required
perhaps it doesnt exist at a say 20-£35 level
