Colour matching
28 Jul 2009
Kent
Hi.
I have core drilled a hole through engineering brick and unfortunately a fairly big area of brick broke out which I need to fill.
I was wondering if using orange emulsion paint instead of water in a sand/cement mix is a silly idea.
The local builders merchants came up with all sorts of coloured dyes and sand but nowhere near my brick sample.
Thanks for reading.
Ray
As Roy Walker would say, "It's good, but it's not right".
Cement dye or a new brick.
Well, in the end I couldnt find suitable dye so I used a 'matchpot' of emulsion paint. Close up it didn't look right (but I think that was just the fact it was the texture of a mortar filling) From ground level or from the windows the other side of the quadrangle the repair was invisible. It was certainly a new experience and a bit messy but the final appearance was spot on.
Been back today (to quote for another job) and it still looks the same so I'm a happy bunny.
I was in the building again yesterday and took the oportunity to have a quick look at this, I'm pleased to say it's still looking good. Yeah happy bunny still.
Don’t you have a camera?
The closest view is 4 stories up from ground level (against the bright sky) or across the quadrangle which is probably 40m. I had my phone with me, which is not a super duper camera so it wouldn't have given any worthwhile image
Under those contidions I couln't see any blemish other than the cable entry but several metres away is a standard mortar repair which is obvious.
Well, the fact that you're still being asked back to quote for jobs suggests that it's acceptable! Unless they're trying to guilt you into redoing it :LOL:
