coloured render
31 Oct 2010
Gwent
i want the front of my house rendered in a coloured render the walls are london brick 50% of which has had roughcast hacked off,i looked at k-rend but i want a smoother finsh and have been told that cantallana is better also that it is less prone to cracking is this so. are there other products. thanks bampi
use webber m8 far more better finish and more colours
think theres some going on ebay at the mo that will be more then enougt for what you want to do
Whatever you decide to use, make sure you seal up those bricks with something like rendaid /hpx etc, using mesh if you need to.
call webber and a rep will come out an spec the job
iv used Krend webber a lot and love it use upvc beads to mach the render
i love working with it nice finish easy to use.
love use upvc beads too id go with webber on this job
I once rendered a house were in the spec I had to mix paint in the mix with snow crete and lime plasterng sand it looked **** hot at the end
first time id used paint in the mix
went throw a lot of paint but the next time they need to paint it i think is 2012 i done it in 2007
