Combi 80 fan query
Bmt
17 Dec 2007
Essex
I have a Potterton combi 80 that I have recently noticed the fan running continuously after the demand for hot water is finished(tap turned off) and no CH on, the fan runs for about 5 minutes and then switches off, this never used to happen. I had a new diverter valve and pump fitted in january but have only become aware of the fan problem lately.
Any ideas or suggestions greatly appreciated.
Check the hot water flow switch (puts red light on, on pcb) is going off properly. They stick.
Try it on CH - same or not?
Otherwise - Ultimately the fan is controlled by the pcb, which is practically a consumable part on your boiler. I expect you've had at least one new one already.
