Hi all,
Current house has a vented Y plan heating system with two bathrooms both with pumped power showers coming off a single tank. This works for now when only one shower is in use which is most of the time.
We now plan to move (or as seems to be the law, replace) the existing perfectly good boiler so are looking at options. One option is a combi which might not be the best solution for two bathrooms - so can we put a combi but still keep the tank?
So is this feasible?
1) The combi would drive the ensuite shower and all sink taps in the house. This pipework would be isolated from the existing tank and vented header system pipework.
2) The combi heating circuit would go via the existing Y plan motorised valve which would circulate the water via existing tank/radiators/both depending on the instructions of the existing programmer/thermostats. The heating circuit would lose the pump and be disconnected from the header tank so a closed loop driven by the combi pump. The bath taps and pumped shower in the second bathroom would keep the existing header tanks and get the hot water from the existing vented tank.
So the combi drives the taps and the ensuite. If we have vistors, we can set the programmer/boost to heat the tank using the combi heating circuit. All the combi will see is a call for heat which could come from the tank thermostat or the hall thermostat, it really doesn't know so doesn't matter.
Would that work? Thanks....
