- Joined
- 18 Apr 2016
- Messages
- 45
- Reaction score
- 1
- Country
I have a Vokera compact 28 SE combi boiler which is about 4 or 5 years old. The issue is whenever it turns on it makes quite a loud noise. A bang is maybe a bit of a strong word but it's like something hitting the metal casing of the boiler and causing a thud. It didn't do it when it first got installed and has gotten steadily more pronounced over time. Any ideas what might be causing this?
Also a second issue is if I run the hot water quite slow there is a terrible rattle from the boiler. Not sure if it's the flue or the boiler itself but it's definitely only when the hot water is run slowly. If I turn up the pressure on any tap it stops rattling. Not as big an issue but still annoying. Any advice what could be causing this?
