Combi Boiler - Bath runs cold
7 Apr 2008
Surrey
We got a new combi boiler less than 2 years ago.
The heating works fine, and the shower which is over the bath and from the same pipes as the bath is fine too
But recently if I run a bath it runs cold then hot then cold then hot - You end up with a luke warm bathfull at best.
I did notice one of the radiators gurgling like mad when I ran the bath, so I whacked the heating on and bled out a lot of air from it.
The problem still persists any idea what else I can try? And is it likely to be anything to do with the radiators? (need more bleeding?)
Rub the bath and stand by the boiler. See if the water is cycling on and off.
Ok, as in firing up and then going off again? It should be constant the whole time its running I assume
Yes. And this isn't happening with any other hot tap?
It doesnt appear to be, and you can take a decent shower with no fluctuation in temperature at all.
I will try testing it all tonight, starting with the tap closest to the boiler.
