Combi boiler, change valves?
18 Apr 2010
London
hello guys
i'm replacing my old not-combi boiler with a new one.
if i do so, do i need to replace the radiator valves and locksheilds? (not sure of the names, i mean the IN and out Valves)?
and in general, is there any other changes should be done when someone changes to combi-boiler system?
You are supposed to have thermostatic radiator valves fitted
to reduce heating costs.
However I have come to the conclusion because they fail or stick
so regularly that they are more trouble than they are worth
so I would leave them alone.
You should certainly have a wall thermostat fitted if you haven't
got one already.
As a MINIMUM you should have Thermostatic Valves on the Bedroom Rads, and a Room Thermostat in the Sitting room to comply with Building regs Part L1. ;)
