I've just had an extension to the side of the house, and in the process my Worcester 240 combi boiler was moved elsewhere, close to a new small toilet. I've noticed now that when the new toilet is flushed, after the cistern is filled, the boiler 'does something' (activates in some way) for a couple of seconds and then stops. I was told that it's because the toilet is so close to the boiler and is taking water from it. But it happens no matter what cold water is run, cold taps upstairs, the outside tap, etc. I can't remember if it did this before, as it was under the stairs. Please can anyone tell me is this normal behaviour. And if not, what can I do please. Thanks!
It tends not to happen when the water is run slowly, and stopped slowly. But opening and closing a tap quickly causes it, as does the toilet flush/fill.
