I currently have a conventional boiler and open vent cylinder with 2 water tanks up in the loft. I have a 1930s 4 bed detached house. i want to get rid of the cylinder and tanks and so convert to a combi boiler. currently considering the Vaillant ecotec plus 937. It will be very rare for two people to have a shower at the same time but I would like to have a shower without the flow decreasing when someone opens the kitchen tap. We have 14 radiators in the house.
Had two plumbers to give quotes. Neither really tested water flow or pressure. One just ran the tap and guessed by eye I had 9 litres/min. I have since measured myself. tested flow into a bucket and it was 17 litres/min and pressure was 3.2 bar at washing machine tap. Upstairs from bath tap the flow was 14 litres/min. The cold supply is 15mm from stopcock. The plumber who guessed the pressure said I should run 22mm pipe from stopcock in kitchen to the boiler. This would be about 1.5m run from stopcock to boiler. Then he suggests running 22mm hot and cold to upstairs as currently 15mm pipes run to the upper floor for hot and cold.
So based on my pressure and flow readings of 17 litres/min at 3.2 bar do you think it is necessary to change the 15mm pipe from the stopcock to 22mm to feed the boiler and then run 22mm hot and cold even though the vaillant 937 only has 15mm outlets?
