CORGIS please help
I have moved a Ferroli Optima 701 combi boiler to a cupboard under the stairs in my house. I now require the gas supply and flue to be connected and the system to be commissioned. However I had a visit from a CORGI installer who didn't believe the flue terminated in a suitable position outside.
As shown in the attached flue position diagrams the flue will terminate outside between ours and a neighbours wall. It is more than 100mm from the internal corners and more than 75mm from the horizontal and vertical soil pipes as stated in the instructions for the boiler (located here).
The CORGI installer made the following points:
- The flue should be further than 300mm from the corner of our two walls
- It should be a certain height above our kitchen door, even though the flue is not directly above the door
- As our neighbours roof is not airtight (where the plastic roof sheets join the top of the wall) the flue should be a certain height above the roof, even though the flue is not directly below the join
I have read that rather than following general flue positioning guidelines, the manufacturers requirements should be followed, which is what I have done.
Can anyone please confirm that the boiler instructions should be acceptable and whether you believe the location of the flue is acceptable based on the diagrams provided here?
Your advice is much appreciated.
