I have an oil worcester bosch combi-boiler with a flue coming out the top, bending through 90 degrees and then passing through the wall and venting.
Problem is the plume of steam from it then wafts across the back of the house blocking the view.
My questions:-
how many bends can you put in the flue?
after 1 90 degree bend, after it goes out the wall,can I put another 90 degree bend, go up a bit and put a vertical flue end on it? By then it will be above the roof line.
My questions:-
