Just been reading a few posts, basically I have a combi and the hot water goes hot then after say 20 seconds it gets cooler and runs cold, then runs hot again and carries on this way.
I have heard it could be a number of issues, ie plate heat exchanger blocked/dirty, DHW sensor faulty, microswitch sticking, and also modulating gas valve settings (high and low) incorrect/drifted etc
How does the gas valve settings cause this fault? Is it because the gas valve canot modulate properley??..
The boiler is a worcester cdi non condensing
Thanks for your help and advice
