Hi All,
I have a WB Greenstar 25si which is really undersized for my property (came with the house, 5 bed, 2 bathroom). I have been considering for a while upgrading it to something more meaty to increase the hot water flow (as I was renovating my house I paid to upgrade the mains to 32mm, cold and hot pipes to 22mm, and gas pipes to 28mm. Pressure from the mains is great as I am very close to the Thames Water treatment facility for the whole of London).
The question that I cannot find the answer to is about getting hot water when taps are half off. At the moment if I turn the kitchen tap half on, I don't get any hot water (I guess the flow switch does not trigger). I can live with it for the moment, but if I upgrade my boiler and nearly double my water flow, I want to make sure that I can still get hot water if for example 1 tap is on and the flow is significantly below the maximum stated flow rate.
Put another way, do the larger boilers, have any automatic adjustment that allows them to slow down the heating of water, when only 1 tap is on, and speed it up when there is a much higher demand? Also, I cannot seem to find anything that lists the minimum flow rate/flow switch trigger so that I can compare models and understand what flow is required to turn the boiler on, is this listed anywhere?
Thanks in advance,
Jon
Thanks in advance,
Jon
