I have a Viessmann Vitodens 100 and the hot water takes ages to come through. I've asked on here previously but done some more tests myself.
This morning the display temperature was at 46 deg C before I turned on the hot water. As soon as I turned the tap on, the boiler fired up, slowly and the display temperature began to drop to around 42 deg C after 30 seconds or so. At this stage, 30 seconds in, the boiler started cranking up to full power and temperature began to rise and within another 30 seconds was up at over 60 deg C.
The installer recommends installing a hot water pipe to the kitchen as the run of pipes is from the boiler in the garage, upstairs, then back down. However, if the boiler itself is taking around a minute I can't see this making much difference.
Compared to other combi boilers, my dads, for example only takes 15 seconds, his is in the loft.
Is it usual for a boiler to take a minute to get up to HW temperature? I have tried comfort and eco settings but it doesnt make much difference at all. I even had Viessmann have a look at the boiler last year but they found nothing wrong. I just can't understand how my dads is almost instant and mine takes a minute. Thoughts please?
Thanks in advance.
Thanks in advance.
