Combi boiler - leak = no pressure
25 Dec 2003
Hi all have a problem with an ideal response 80 Combi boiler.
Basically In a state of intoxication a radiator started leaking after I leaned on it. The heating was then turned off and buckets placed under it and we think we fixed the radiator this morning, however the boiler when we turned it back on read 0 pressure and doesnt seem to start up etc. If anyone can give me the remedy to this it would be much appreciated (especially as it is my friends place and he is none to pleased with me / having no hot water at christmas)
Thanks in advance for any help you can offer.
If you've fixed the leak, find a flexible connection near the boiler from the cold supply to the heating system, you should have to make a connection , but the pipe may be connected. Open the tap one end (or both ends) but open the cold end SLOWLY and raise the pressure to just under 1 bar.
Then get someone who knows what they're doing to check it soon.
