I have a Vokera combi boiler in a flat with about 7 radiators, but it is loosing pressure if anyone can advise me on the best course of action.
This morning I topped it up to 1 bar but now 12 hours later it is at
0.6 bar.
My down stairs neighbours haven't complained about any leaks, I'm not sure if the pressure relief valve is faulty and letting water out, I can see the outlet outside but can't get a good look at it because I'm on the 4th floor, but I haven't visually seen any water drain from it.
I've lived in the flat for a few years and it has always needed topping up now and again, about a year ago I put some of the below Sentinel leak sealer in it:
https://www.screwfix.com/p/sentinel-internal-leak-sealer-1ltr/99730
This seemed to make it settle down a bit, but in the last couple of weeks it's started dropping quite quickly.
I've bought some of the below to put into it:
https://www.screwfix.com/p/fernox-f4-central-heating-leak-sealer-500ml/45902
I'm really hoping that putting the fernox into it will stop the pressure dropping, but I've read some places that leak sealing liquids can damage a combi boiler?
Might the fernox react badly with the sentinel that I put in previously?
I'm not sure what other alternatives are, I'm praying it doesn't come to tearing up floorboards to find a leaking pipe.
In the past the pressure drops seem to be kind of random, for a few weeks it will be ok then all of a sudden it will gradually drop down a bit.
0.6 bar.
