My Worcester 28KW combi boiler is losing pressure. If I fill it up to 1.5bar it will have fallen to zero over 10-12hours.
Called out heating engineer who found expansion tank full of water. He re-pressurised it and cleaned PRV.
Everything worked perfectly for 1 week and now it has started losing pressure again at same rate as before. I am having to top up morning and evening.
There is no water dripping from pipe outside and we’ve had all floorboards up and no sign of a leak inside.
Engineer says it impossible to tell what problem is. Only thing he suggests is to start changing parts, starting with PRV to see if that works but there’s no guarantee that this will sort it.
Does this sound right to people? Surely he should be able to tell more precisely what the problem is. Any suggestions? Should I contact another plumber?
Many thanks.
Many thanks.
