I moved into a new build flat 3 months ago, all rooms are on one level. Ther is a combi boiler installed, Glow Worm 24 ci, and a thermostatic(?) mixer shower installed, Meynell v6. The problem is that the shower is never hot enough.
The shower mixer tap only controls water temperature, cold then turning up to hot, with no loss of water flow at either end of the temperature spectrum. But even turned up full, the shower is still not hot enough.
My husband decreased the mains water pressure - it gushed out the kitchen taps and soaked everywhere anyway - and I think it helped somewhat. But it's still not too good.
The pressure reading on the boiler is 1.1 bar, so I assume that should be adequate.
But what can be done about these lukewarm showers? Are there any tweaks or adjustments?
