I've an Icon T combi boiler - no other markings or part numbers. From reading around it may be a Herman re-badge. Has a SIT 0.537.301 electrical box on it and what looks to be a CEME Eng pressure switch, partial p/n 5412/VAP-DR (?). Unable to get DHW from the system unless the CH is running, in which case hot water is usually available. Has been suggested the pressure switch is u/s. Any way to test this? Further info - have continuity between terminals at 12 and 3 o'clock, nothing between 9 o'clock and 12 or 3 (no terminal at 6 o'clock), with hot water tap running and not. Boiler switched off for this test.
Any info appreciated.
