Hi all,
Hope someone might be able to help, as I know nothing when it comes to boilers, but I'll post what I have tried (either rightly or wrongly).
We have a Chaffoteaux & Maury Britony Combi 80 (47-980-12) boiler, which is having problems.
It's occasionally firing up, but it doesn't stay lit for more than a couple of seconds, which means no heating or hot water.
If I turn the hot water tap on, I can hear it clicking over from central heating, but the pilot only ignites every 1 in 5 attempts.
I've released some pressure from the system (by draining some water from a radiator), then pressurised it back to 1 bar, but still no difference. I also unscrewed the pressure release valve at the back of the boiler, and only water came out, so doesn't seem to be air trapped in the system.
I've switched it off for 5 mins or so, to see if it needed to reset itself or something, but no luck.
Any advice would be great - unfortunately I can only find a manual for the newer model of Britony 80, which has different parts / layout to mine, so you'll have to speak about things in laymens terms.
Cheers,
Oli
Cheers,
Oli
