if you are looking for a shower that will blow the skin off you, forget fitting a pump to a combi, if you can imagine, the combi is like a kettle and cant heat the water quick enough to cope, for talking sakes, if you need 10 ltrs of water per min and the combi can only heat 5 ltrs per min, its just not gonna happen....i have therfore just installed a 120 ltr unvented pressurised hot water tank, which gives you roasting hot water at mains pressure, and fitted a mira shower mixer valve, took a bit of messing about, but compare my shower to any electrc or pump shower and you will see what i mean.....if you are filling a bath the hot water flys out of the tap at the same pressure as the cold, its pretty mental, £475 from plumb center.....chheeeers, Dan
