- Joined
- 27 Jan 2005
- Messages
- 12
- Reaction score
- 0
- Country
Ok, newbie entering the scene...
Hi All,
The prob. started on wtues night when i bled some air of my farthest rad. initially all went well, rad. filled with hot water smiles all round.
within 30 mins the heating had shut down and refused to start up again and no hot water was available. I could hear boiler fire so knew pilot was not problem.
Took advice at work which suggeswted i shoudl crank pressure to free the diverter valve. retunring home i opened the grub screw on the hot water pipe and heard the pipes/system immediately fill with water (heating system switched on) and i kept valve open until i knew all rads warm and pressure correct.
This morning awoke to find that the heating had once more shutdown (hot water available tho) so again bled off a bit more air in the rads. and filled the pressure to 0.7 bar as recomm. in the boiler door notes.
All fine and well. retunred home from work this evening to find pressure of system was at 0 and rads obviously would not warm up. again opened up grub screw and let hot water filter thru until i got to the 0.7 bar. fear i shall be repeating this in the morning.
should i be increasing pressure with the system off?
where could the water be going to drop the pressure so significantly?
Anyone got any advice?
Details of system are:
Glowworm Swiftflow 80 gas combi. (small red cistern sits on floor beneath - is this an expansion cistern?); radiators throughout.
Thanks in advance,
Liam
Hi All,
Thanks in advance,
Liam
