Guys
I am still learning about boilers and central heating system.
My W Bosch 28i may need re-pressurising - a layman's educated guess?
Please advise if you can:
Pressure fine at 1 bar most of the time.
In evening sometimes, it drops to just below it but always go back up to 1bar eventually.
Hot water working fine.
Now that C Heating is at full blast in most rooms of the house, I have noticed that when the boiler starts days for the C Heating, pressure drops from 1bar to 0.75 bar (The drop is normal from what i have been reading with the pump coming on - unless I am totally wrong). It stays this way however and only goes back up slowly with time - 1-2hours - to 1bar.
Central heating working fine - first and second floor
Radiators in loft however only hot at the bottom (have just started to use them recently)
Is the significant pressure drop from boiler normal? Is it related to the cool radiators in the loft which I have only just recently started using?
I don't think the pressure drop was as big as now before I started using the loft radiators which are not working efficiently anyhow.
Shall I re-pressurise the boiler to say 1.5bar?
Thanks!
Thanks!
