I have a Worcester 240 Combi. occasionally when I run a bath the radiators also ostart to heat up. Could anyone advise on what the problem is. (or should I just buy a new boiler as it's a bit long in the tooth now hehe)
if it is just the one rad then it may just be plumped in to hot water side as use to do this so you had a warm room when you had bath but unlikly as was old system boilers not combis
