Hi
Please help... a problem with hot water and no plumbers seem to be available to help in the next month.
The problem is that the boiler seems to cut out intermittently. The problem is particularly bad with the shower. It will provide hot water for about a minute, and then gradually the water gets cooler and eventually cold. You can sort of 'jump-start' it again by turning on the hot tap to full blast and then the shower will heat up, but it cools down again after another minute or so.
The system pressure is at almost 1.5 bar so I don't think that's the problem but I really have no idea what else it could be.
The problem also exists with the other taps in the house...
thanks in advance.
thanks in advance.
