Hi
My combi has two pumps in. In the manual, it says one is DHW and one is for heating.
They are both Grundfos 20/60 with adjustable speed settings of 1-3.
By default they were both set to 3. I changed the central heating one down to 1 as it sounded like a jet engine inside the house with the water rushing around my pipes!
What does the DHW pump actually do? What affect will changing the speed on this have? The speed at which the water comes out the hot tap is determined by the pressure of mains - correct? So does this pump move the water through the heat exchanger at different speeds?
Thanks.
Thanks.
