With a combi boiler supplying hot water to a tap/shower mixer, does the cold supply have to be mains fed, or can it be supplied via a tank.
Also
If you are supplying the cold from the mains, would you normal supply the water to toilets from the mains or a tank.
Would you also restrict the mains cold supplyt to the tap to stop it spraying everywhere.
Also
